Ik las dat je de AB kan herprogrammeren volgens onderstaand protocol, maar ik heb daar geen ervaring mee. Straks doet 't UP-je het niet meer. Iemand ervaring mee?
VW Volkswagen Step-by-Step FREE Fob programming guide: (1997 ON)
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Driver's door by using a spare key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait for 6 seconds and then press the unlock button once to activate the coding procedure. The remote control should now be programmed.
PLEASE NOTE : When performing programming on additional remotes the procedure is the same, except you press the unlock button 2, 3 or 4 times for the different remote e.g., if programming 2 remotes press the unlock button twice with a 1 second interval between each press. Repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
