Storing Cruse controle
Geplaatst: di 13 aug 2024, 13:27
Zijn er leden die hier een wat specifiekere oplossing voor hebben dan de fout code van Gerrit Speek of Rosstech Wiki, mischien een gecorrodeerde stekker of zo, en waar die dan moet zitten.
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 AP HW: 04C 907 309 P
Component: R3 1.0l MPI H23 9101
Revision: UNH23--- CVN: F7B7C5FB
Coding: 00110032022401000000
Shop #: WSC 00404 211 00000
ASAM Dataset: EV_ECM10MPI01104C906020AP 001008
ROD: EV_ECM10MPI01104C906020AP_VW12.rod
VCID: 698FBD1489F842F2E0D-803C
VINID: 9E69EAAAA451A95501042007109D5CEEDE
1 Fault Found:
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [00100100] - -
[Function restriction due to implausible message]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 157829 km
Date: 2117.14.22
Time: 11:42:00
Engine RPM: 2732.00 /min
Normed load value: 54.9 %
Vehicle speed: 60 km/h
Coolant temperature: 89 °C
Intake air temperature: 43 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.536 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible-Bits 0-7: 255
Acceleration: 0.380 m/s²
Readiness: 0000 0000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 157829 km
Date: 2117.14.22
Time: 11:42:00
